im at a road block with my engine rebuild.the new custom diamond pistons just came in for it. 4.600 bore 598 conv head motor.they are built for 2 stages=500hp juice and motor should make about 1050 n/a.the pistons weigh 784 grams each bare.i plan on spinning it as hi as 7700rpms.i dont know if it will even want to spin up that hi with that kind of weight along with the steal rods or if feel safe to try.was planing on running my oliver billet rods which are about .825 grams.the crank is gonna need some heavy metal to rebalance also as the old pistons were 706 grams with a lighter pin.im thinking i may be better off going to a grp aluminium rod. i checked with them and weights are about 200 grams lighter per rod.
