Hi guys. I have a NOS Cheater kit on my car. When I let go of the
transbrake it launches good
but as soon as it comes down it loses power and starts to sound like a 2
stroke dirt bike when you down shift too far. No popping or anything and
it makes a good clean motor pass, but when the kit is activated, it acts
up. I have 6psi fuel pressure and 6 degrees of timing out with a 180
shot recipe. I have 116 Sunoco in the fuel cell and a .035" plug gap. I know that's way conservative, but I want to be careful. The motor is a 434 sbc with 13.6-1.
I still have not made a good N2o pass with the t-brake. Im using an MSD 7AL3. Could there be a prob with the t-brake that could cause the nitrous kit to act up? Do I need to put a resistor or diode or something between 2 of the terminals on the relay? Should I use one of those 80amp continuous duty solenoids for the nitrous instead of a relay?
Thanks for any input.
