1 - 4 of 4 Posts
Ok guys. I am struggling with how to set up my purge kit. Kit will be on a motorcycle, so I am limited on space.
I just need to make sure I am thinking correctly here... air in the lines will cause a backfire, right? So, thinking this, should I place my purge solenoid right next to my spray solenoid, which would clear all of the air except what is after the spray solenoid? Is there a way to do this better? Just trying to get the most efficient nitrous setup I possibly can.
Next question is... I want to run 2 dry stages, but like I said, I have very limited space. Would it be possible that I could use wet nitrous nozzles, and add in the second stage through the same nozzle?
I appreciate all the help guys!
Matt K
T/S 368E
No room on my car so I ran a fitting in front of solenoid and mounted the purge noid a couple of feet away.
As long as you are clearing the line, I would not worry about wasting a tiny bit of N2O.
Besides I waste more getting the pressure right, then clearing the air.
Just put it where you can. It is for clearing the line. And yes many people use wet nozzles to make two dry kits.
Discussion Starter · #4 ·
Cool, thanks guys!
1 - 4 of 4 Posts
