1 - 5 of 5 Posts
I have a 93 fox body mustang with a 540 in it. The car runs between 5.70 and 5.80. I am going to put a shot of spray to it to see what happens. The only thing I am concerned with is it is a bracket motor and does not have the right cam. I would like to spray 200 if possible running alcohol. My question is can I run this and how much will I gain in 1/8th?
I run 6.0 index on ALK & belt pump and put a big shot plat on it but I spayed it with Q16 out of a gallon cell and a holley blue pump and pulled timing out and it would go 6.11 on motor and 250 shot it would go 5.60s at 129 mph and the cars wt# 3,210 lbs with 31x10.5w and lot of has to do with your converter to if it is lose the more you spray the more it will blow by and not make power .
Converter will play a gigantic role.
Was the converter SPECed for the alcohol motor,if so its tighter them it would be for a gas one,a200 shot would be max id put to it
1 - 5 of 5 Posts
