1 - 3 of 3 Posts
I viewed the info Monty has on wiring a circuit to avoid nitrous activation when on the transbrake......It won't work for me without alot of rewiring......What about this...Car leaves on two step at 4800rpm. The nitrous is on a 30 amp 5 pin relay. The nitrous has an arming switch which goes to #85 on relay. #86 on relay will go through a micro switch on the throttle(WOT) to the yellow wire on a MSD RPM Activated Switch with a chip higher than 4800rpm to supply the ground.
I asked MSD about this and they indicated it would take two relays and were to send a fax (no show). I'm not wiring into the transbrake....just kicking nitrous on at a higher rpm than the 4800 launch. I do not see the need for another relay, am I missing something?
thanks,
Mooreboys
I don't see any problems with what you have described if all you’re doing is bringing the Nitrous on at a higher RPM.
If future plans are to turn the Nitrous on after letting go of the Trns Brk, there will be a delay and 60' will be affected. Wiring a relay in to interrupt the Micro sw while on the Trns Brk is the only proven effective method.
I hope this helps clear up any confusion, if not let me know.
Thanks for inquiring
Sparky
TURBOBULLET.COM BITCHES!
Can't you just wire an additional relay to drop voltage to the arming switch while the transbrake button is held???? That would only be changing 2 wires, and it would work fine....
1 - 3 of 3 Posts
