What does it run on motor? By the MPH you have there is a bunch left in it. I have only made a few 1/4 mile passes, but i went 7.60 at 176. On the bottle i went 7.25 at 161 clicking the motor at 1000'. i turned the bottle on at .3 and off at 3.8. 4.51 @ 155 in the 1/8 on that pass. Are you adding the extra fuel through the EFI or are you adding extra fuel through the plate?
I have been changing things all year, so that doesn't have a simple answer. I have had three converters in it, different tunes. I think the cam is wrong, needs more advance and need to play with when to bring the nitrous in. Best NA pass I can recall (don't have the computer with the data in front of me) was 8.01 @ 168. That was in poor air (~3,000ft DA) as was the best nitrous pass.
What are you thinking is wrong or unusual? Do you mean it should ET better for the MPH? The 60" on the quickest pass was 1.201 with nitrous on ~0.5 sec after the car leaves. Just turn the tires a couple of revolutions. All I have control of with the current system is time delay before the nitrous hit. When I go to the high-po nitrous next year I plan on a digital controller. Current system will support 300hp and will try that before the year is over. Want to get a handle on the 74 jet first though.
I have been "guessing" at fuel jet sizes just based on what I know about gas and nitrous and the stochiometry. Just from the chemistry I am using 2.3 times as much alky as I would with gas. The base fuel map is rich anyway, so I am tempted to experiment with leaner to heat it up.
Any thoughts are welcome. I really prefer alky and want to see what can be done with it and N2O. An old timer I know insists that 300hp is practical limit and that power loss vs. the potential with gas really starts to get bad above that. That's why I am wondering about the whole compression thing and trying to figure where to go with it.
Another thing I have been wondering is whether to add the fuel through the injectors instead of plate - which would work better? I am thinking the plate has a better chance of the fuel and nitrous going to the same place.
