1 - 8 of 8 Posts
T/S 368E
Have to add a nine bar to a car. Need to know what the exact location specs are. How far in front of existing bar is it needed.
I heard it's 1 1/4" @ .058 minimum?? Was thinking of adding 2 bars, one where required, & one more about where knees are.
Safety is more important than weight. Any info or thoughts, would sure help. Thanks guys.
T/S 368E
Discussion Starter · #2 ·
Nobody here has the spec sheets, or am I using the wrong terms??
I usually make that bar out of 1 5/8 only to keep the the top of the bar floor height, I do 2 diagonals 1 in the seat area and 1 in the foot area (like a 25.2)
I usually place that bar at the vertical line of the front of the drivers body, just like you would place a crotch strap tab...
There are no specifics on a measurement for it.
T/S 368E
Discussion Starter · #8 ·
Ok, so it sounds like as long as it's there somewhere close I should pass. Still going to add a second bar at ~the knees
& maybe even make it 3 bars evenly spaced. Thanks guys.
1 - 8 of 8 Posts
