Not much. Just cruising craigslist for a parts car for your Regal parts and 63 or 64 Fairlane parts for another potential customer.Check!
Whats up?
Wassup?Howdy
Trying to understand C16 a little better...Wassup?
The fuel?Trying to understand C16 a little better...![]()
YesThe fuel?
are you ready for my parts list?supp fellaz
been a long day of working in my garage on a day off-looks great!
Do you have any idea what it weighs now? My car with all steel body panels, no hood on, 8.50 moly cage, all TRZ and Strange stuff, all aluminum SBC/TH350, 9-inch, full interior, full 16 gallon cell, weighed in at 2833 pounds. I could easily get it under 2700 just with CF doors and bumpers!! Maybe even close to 2600 without filling up the fuel cell and doing the full CF treatment.I am really curious of the total weight and the ET difference just putting the slut on a diet...pretty excited about it...I might not even paint it haha.
I've never used C16, just C12 and Q16. Anything I can help out with?
I'm thinking of running it in the Focus at the track to make it safer and bump the spark up above 5k rpm. I'm trying to understand the spec gravity of C16 and how that will effect my AFR over the pump 93 it's tuned for now and if it will richen the mixture on the same fuel maps, how much that would slow me down.I've never used C16, just C12 and Q16. Anything I can help out with?
How extreme do you plan to make it? Are you planning to keep the Buick 455 and TH400 in it?Its full running weight so probably around 3400??
I'll bet a quick call to your local VP rep would probably be able to give you all the information you need. I would imagine that you should be able to simply adjust fuel pressure and timing to compensate for any differences, right? Do you have any sort of real time AFR reading ability for tuning?I'm thinking of running it in the Focus at the track to make it safer and bump the spark up above 5k rpm. I'm trying to understand the spec gravity of C16 and how that will effect my AFR over the pump 93 it's tuned for now and if it will richen the mixture on the same fuel maps, how much that would slow me down.
