21 - 40 of 153 Posts
Smart Ass Conservative
Discussion Starter #22
I've got the scoop on a 70 Super Bee 440 6pak from an old Popular Hotrodding mag.
Hit the rollers stock and it made 244 @ 4250 at the rear wheels, with a 4.10 posi, F60-15 tires at 23 psi it ran a best of 13.95 at 100.78. With a dyno tune and 36 degrees of timing it made 272 at 4250 and ran 13.74 at 105.63. With a set of 2" fenderwell style of headers and mufflers hooked up it made 318 at at about 4700 rpm and ran 12.92 at 108.42 with the headers uncorked, hood scoop open, tire pressure at 14 lbs. and pulled 5000 rpm thru the lights. I think that's pretty much as true as it gets. :cool:
Discussion Starter #23
To compare.....
Same mag, 1970 Cyclone standard 429, C6 auto, 600 autolite, 3.00 rear gear, one wheel peel, car weighing 3850 ran 15.30 at 94, added 600 holley and ran 15.14, added CJ cam, springs, ect, dual point dist., CJ cast iron intake and 780 holley and it ran 14.79 at 99mph, added 3.50 gears, locker and slicks and it ran 14.25 at 100 mph, added headers, no exhaust and it ran 13.57 at 105, added 4.30 gears and it ran 13.47 at 108, added Mondello ported standard heads with CJ valves and it ran 13.22 at 111.38, added CJ hyd. cam and slowed to 13.36 at 108, added B&M 10" converter and ran 12.91 at 107, added H&M 300 degree cam kit and ran 12.78 at 111.52, added a 460 cuin 426 HP and 10" slicks and it ran 12.57 at 111.11 mph.
The super bee was a 4 speed.
Discussion Starter #24
And to compare....
Early 80's, my 1968 xr7 GTE 427 cougar, stock short block, home ported 360 truck heads with 428 CJ valves, JC Whitney 300 degree cam kit, hooker 1 3/4 headers, full exhaust, 780 holley with stock alum PI intake, 3.50 gears with one wheel peel, L60 sticky Mickey's, C6 with 10" super hole shot converter, and it would run low 12.80's at 110 driven to the track.
Discussion Starter #25
1988 Mopar Action mag., 1969 Dodge Hemi Daytona auto (1 of 17?) road test/drag test, fresh rebuild, much tuning to get to run right, powerbraked at 2000 rpm, stock looking tires and 4.10 posi ran the best of 13.9 at 105.65.
Discussion Starter #29
I really like those old Chryslers, I remember as a kid seeing a convertible white 55 or 56 300 with gold trim running around Terre Haute IN., I always figured it belonged to one of the Hulman's.
If you go to Google Earth street view, that green 70 Dart is in front of the shop
1260 Rue Tellier, Laval, QC
Aviation Section
To compare.....
Soooo...The moral of the story, 385 Series FTW!
Dave
Discussion Starter #38
Nick's kicking it with some fords this week, must be running out of ideas, lol.
