1 - 2 of 2 Posts
sorry if these questioons are stupid, ive tried searching for some of this stuff but i dont see answers on alot of things. im going to try to to build something with alot of my own labor but info seems tough to come by
are turbos from precision turbonetics and other manufacturers the same? will a 101 from one company bolt up the same if the car is built with one from the other? will a 91 bolt up the same as a 101 or 106? id hate to have to make all new tubes just because my turbo broke.
is it good to put vbands on everything? or should i put rubber on some places so its easier to work with?
im sure i'll haqve alot of other questions thanks
if im correct,if u get large frame turbo(s) then it will bolt up if diff company,as long as they all r the same flange (large frame). Also some people weld v bands on turbo but ive been told not too,i will be using silcone tube from race part solutions.
1 - 2 of 2 Posts
