1 - 4 of 4 Posts
I'm looking at a F2 and was wondering the whats better side mount or crank and why and how much comp.w/alcohol
Gear drive is the way to go if you can afford it. Less things that can go wrong. Side slingers are known for (throwing belts, the twisting and flex that takes place on the head unit, tension on the head unit berrings) Plus unless it is a reverse mount you will be drawing air in from the engine bay not from the front of the car.My motor is 10-1. Built for alcohol. IMOP.
ditto
1 - 4 of 4 Posts
