1 - 20 of 23 Posts
Here is Racecraft's NEW Prolite Housings for stock suspension Mustangs........Camaro housings coming soon.
Non- Floater housing weight 58 lbs
Foater housings weight 68 lbs
The 4130 housings feature:
  • 3/8" Face plate CNC machined after welding for a true bolting surface for the third member
  • Minimum center section size to decrease amount of gear lube need.....uses 1 1/2 quarts of gear lube.
  • 3 1/2" OD x .187 wall 4130 tubes
  • multi-plane brace to increase overall stiffness
  • 1/2" control arm holes on 3/4" centers with doublers on uppers and lowers
  • Pro Jack mounts incorporated into brackets
  • ARP mounting hardware, fill cap, drain, and vent included
There are more photos here:
http://s1190.photobucket.com/albums/z451/racecraft/
Pricing Info here:
http://www.racecraft.com/index.php?main_page=product_info&cPath=204&products_id=1544
SOFA KING WHAT?
Mark I have a 3rd gen Camaro I'll send to you for mock up!
HeadCaseRacing
Thats just ART work. Looks sick like every thing you guys do. Saw it at the YB nats and its sweet
Discussion Starter #18
Its not a sump. Looks to be a wish bone mount to me.
Send me one Mark!!
Hey Shag! you are correct the wishbone mount looks so big because the housing is so small.
The housing center is just big enough to fit around the chunk.
The small center allows for less gear lube.
Very nice looking piece.
1 - 20 of 23 Posts
