1 - 3 of 3 Posts
Just looking for a good starting point with new strange double adjust on the rear. Stock suspension 68 camaro. I had single adjust that were set on 3 clicks from the softest. Car would leave good using the double for the radials.
You would have to shock dyno them and set them to where you other shocks where to start
I have the Strange dbls. S5064's on the rear of my Nova. They seem to work best allowing for easy separation, 3 clicks in from loosest rebound / extension setting, like you ... and I have my compression set at 8 clicks... seems to keep things planted for the most part. That's what works for me... You will just have to play around with it.... but I'd say definitely looser on extension.
Or you can be a nerd and do what Jeff mentioned... ;) Just kiddin Jeff.... you been drinkin? "set them to where you other shocks where to start" ? :confused:
Cheers.
1 - 3 of 3 Posts
