1 - 15 of 15 Posts
all motor
388 sbc n/a
baby afr 210's
~2950lbs
1.36 off idle :cool:
Thanks to Cordova and my friend Steve for all his help!
:-Daw
Please tell me more about the combo.
350 SBC
wet sump
3.625 stroke
4.040 bore
6 inch rod
JE Dome pistons
14.1 compression
AFR 210 cylinder heads
flow: INT 310 @650 lift, EX 225 @650 lift
INT valve 2.100
EX valve 1.600
crane cam 4/7 swap, INT 268 @50, EX 272 @50
108 lobe separation
Jessel shaft rockers
Ported Elderbrook 2925 intake
1000cfm Prosystem carb
vacuum pump
Q16 fuel
Engine made 653HP @ 7100 and 535FTP
Best 1/8 mille ET 6.16 @111mph
Best 1/4 mile ET 9.73 @137mph
350 SBC
wet sump
3.625 stroke
4.040 bore
6 inch rod
JE Dome pistons
14.1 compression
INT valve 2.100
EX valve 1.600
108 lobe separation
vacuum pump
Q16 fuel
Very nice. What conv and gear. Thanks for sharing thats cool
388 sbc n/a
baby afr 210's
~2950lbs
347 sbf n/a
baby afr 185
2740
pump gas & drag radial 1.46 leaving off idle.
:yawinkle:
Just giving you guys a hard time, I was there on the 16th and first pass down the track after they had to dry it off. I dig Cordova and that track works darn well.
What was going on on the 2nd there?
1 - 15 of 15 Posts
