1 - 20 of 41 Posts
There is probably nothing more satisfying than the moment you start up an engine you have spent weeks, maybe even months building for your ride. Countless hours making sure every technical issue is worked out, tolerances and clearances carefully measured, and each component carefully inspected. Then the day comes that you are ready to lift the engine off the stand and put it in the car. You get a friend to come over to help with the job, and after a couple of hours you cinch down that last bolt, check everything twice, hook up the battery, and hop in to turn the key; your heart skipping a beat or two as you await the beautiful sound of the fresh engine as it comes to life...
https://flic.kr/p/TvKdKQ
I would shoot the friend...
KEVIN CAPS LOCK
SNEAKY FUCKER...PERFECT BEAT THOUGH
One word.
PRICELESS!!!! :)
Senior with common sense
done that to a buddy after an oil change....
1 - 20 of 41 Posts
