Not with those numbers it won’t be. Good try though...
Obviously you didn't read the whole article. Forged crank and rods, Room to bore it out and also has a low compression and a tow cam not a performance cam, Sounds like it has a lot of potential to me.Not with those numbers it won’t be. Good try though...
I think he means both engines in stock form!!Obviously you didn't read the whole article. Forged crank and rods, Room to bore it out and also has a low compression and a tow cam not a performance cam, Sounds like it has a lot of potential to me.
It's 401 and 464 not 491 and 464!!That's actually pretty good - 491/464. The 5.0 Coyote only makes 420 lbs./ft. torque.
I expect the Ford 7.3 to make 420 to 430HP and between 520 and 530 torque.
Good times for hot Rodgers of all stripes!
Oops that was TYPO on my part! I knew it was 401.It's 401 and 464 not 491 and 464!!![]()
Read the article on this engine a few weeks ago, and again yesterday. The power output “stock” is nothing to write home about. As far as hard parts, I wouldn’t say that this 6.6 gasser has any edge over the 7.3 other than aftermarket parts already in place. Same basic design for 20+ years nowObviously you didn't read the whole article. Forged crank and rods, Room to bore it out and also has a low compression and a tow cam not a performance cam, Sounds like it has a lot of potential to me.
TruthWe've all become very jaded......400hp small block that can be found in a truck.......and we turn our noses up.....damn.
For the record, I'm just as guilty.
You are right on that. I can remember the days that if you made over 300hp you had a pretty bad street car.We've all become very jaded......400hp small block that can be found in a truck.......and we turn our noses up.....damn.
^ this.You are right on that. I can remember the days that if you made over 300hp you had a pretty bad street car.
