1 - 20 of 49 Posts
Last friday night I posted a new personal best of 10.96 at 122. Before you laugh check out my combo
92 S10 truck
stock NON posi rear end 3.73 gears
355 cid
Hyd cam-not big either
650 Demon Carb
Cast crank
9.75 to 1 pistons
TFS heads
150 shot
3200 lbs, of Street legal 1 wheel peel fun
can't wait till next year we are making big changes over the winter with new chassie work and maybe just maybe a new motor.
Good job! not trying to be an asshole (I don't even have to try :-D ) what was you 60' or better yet your 1/8? I'll bet it pickked up big time out the back
Yeah the 60' was 1.69 and the 1/8 was 7.0048 at 100 even. It really charges when i get to high gear
did it have slicks on it? sounds like you got a good bit left in it...have fun and stay safe :D
Yes I use a 28'x 10.5 et street. I think I can get a lot of weight out of it, still has full int, including radio and speakers. I would love to see a .80 maybe a little more No2 and hit a .70. It all depends on how long the rear holds together. Its like using a tooth pick to build a bridge
92 S10 truck
355 cid
650 Demon Carb
Cast crank
9.75 to 1 pistons
TFS heads
150 shot
What size trans are you working with?
Discussion Starter #7
Its a TCI th350 with a 4,000 converter. I could use a little less converter with the No2 I seem to drive through this one, but it works.
Discussion Starter #10
Thanks Monty, even mostly stock SBC's kick ass
Discussion Starter #12
She just likes it because they are cheap, enough left over to spoil her when i'm done. or is that soil her? :-D what ever it is it makes me smile
Discussion Starter #15
No fords, never never never. although the lack of power would be much eaiser on driveline parts :-D
Discussion Starter #18
sorry I just have to keep the faith. it would be faster if i put the motor in a mustang :-D
1 - 20 of 49 Posts
