Took my car out for a ride for the first time today. When I got to where I was going I opened the hood and found oil film all over the shock tower. It's coming out of the filter on top of the evaq. canister. On the way home I got on it a litttle and the oil pressure started dropping the higher the rpms went. It started at 50 and went down to 20. If you drive normal it's 50 but as soon as you get on it it starts to drop. There is now a lot of oil all over form the evaq. canister.
I had the engine built by a local well known builder. It's a freshly built 468 with 9.7-1 comp. Dooe-r heads, hyd. roller cam with roller cam brgs. It has an evaq. pump. I wondered if there could be too much oil up top?
