1 - 13 of 13 Posts
I have a 355sbc with a s480 turbo!
I just installed a jgs 60mm gate and it won't make any boost at all!
I have a 2.5 inch diameter pipe running to the bottom of the gate off the header merge.
I have the reference line off the turbo compressor to the bottom of the gate. I have the top vented to the atmosphere with the heaviest spring it made 0 pounds of boost!
WTF!
Is this gate too big?
Did I hook it up wrong I assume it is like all other gates and the reference from the turbo goes to the bottom.....it had no instructions with it!
Please Help YB!
Discussion Starter · #2 ·
There was an extra piece that machined piece that pushes on the valve! Should I have no put that in?
Yes it will need the valve seat.
I just went out there I think that the compressor housing was not on properly I will test tomorrow! To late tonight!
Don't even bother starting and testing the car until you put the valve seat in - without it it is like the gate is open - you will not build boost. Put the spring in you want for base psi and put the seat in and you will be fine.
Custom Engine Shop
As stated that is the valve seat. No seat no boost....
IT has a v-band. Pop the v-band off and install the seat.
Discussion Starter · #9 ·
I always had the valve seat in the gate! Like I stated last night I went back out and I had taken the compressor housing off to drill and tap a boost reference and I guess I didn't have the compressor housing on properly! I drove it this morning and it makes boost just fine. The problem is I have the biggest spring in so I'll have to go back and put the light spring in to see how low the boost goes!
Thanks for the help YB!
Custom Engine Shop
Right-on. Get the spring swapped!
Discussion Starter · #11 ·
I was amazed at the quality of the wastegate when I first took the small spring out! These wastegates are no laughing matter! They are super nice! I'm glad I spent the money and got a JGS!
1 - 13 of 13 Posts
