Ok guys I need some help with my next race truck motor build. I don't drag race like most of you do. I run 150ft side by side mud drags. Now with that said I'm needing to build a motor that will make 800hp and pull 15 inch of vacuum.
So here are the rules for the class I'm running.
500 cubic inches limit
cast heads
single carb.
no nitrous or anything like that
motor must pull 15 inches of vacuum
must be factory chevy block
That's where I stand with the motor part of the rules. The rest of the rules are more about the truck and tires.
Now I'm stuck between a 421/427 sbc or 496 bbc. I am new to building gas motors. always played with diesels still I started racing mud trucks. So I'm here asking for some help.
cast heads
single carb.
