1 - 6 of 6 Posts
I have a new 582 BBC N/A motor going together and it should make just over 1000hp. The car is a first gen Camaro, stock suspension car and should weigh in around 3400 lbs or so (possibly less). What trans, trans gearing, conv and rear gears do u guys recommend? Like I said this is a N/A combination.
Thanks,
Mike
My opinion is a TH400 with a 2.10 first gear and 9.5" converter. This is assuming that you will be turning the engine past 7,000 in order to a grand on the pump?
1 - 6 of 6 Posts
