1 - 14 of 14 Posts
What are you guys using as a mold, I need to make a tube between the bumper and the inlet on the turbo.
Phil, give Schoneck a call he has a tube that he makes just for this
Go to Hobby Lobby and ge the Green Foam women use for making Fake Plants... Its the "Base" it comes in bags... and comes in 2-3" thick Layers... and shape it and get your overall Length.... Then use that as a Mold for the Fiberglass... and Pick out the middle....
Bleach bottle.fiberglass doesnt stick to it.pulls right out and leaves a perfectly smooth finish/
thanx for the bleach bottle trcik man
Discussion Starter · #10 ·
Do you need to grease it or use wax paper or just fiberglass and go?
x2. This is what we used. It's quick and easy, and it's not that much money. Comes with glass and resin for installation as well.
You don't need to do a thing.the glass won't stick to it.cut the hole the size of the bleach bottle.shove it in the hole and glass it from behind.when the glass dries.just remove the bottle.
Fiberglass doesn't stick to an OEM (Plastic) bumper.now if you glass it from the rear and make the flange wider,you might be able to bolt.pop rivet it to it.
1 - 14 of 14 Posts
