1 - 6 of 6 Posts
Hey all, getting my fogger plumbed shortly. What would you all run for fuel on 13.5:1 turdstang 363
with my plate ran around a 170 shot with 110 renagade, 26 degrees of timing with a ngk 10. Would you guys recommend a different fuel with say a 225 ish shot on a fogger? Different plug?
The plug will be fine I would go with c16 on fuel to be safe
It sounds like you are already very conservative on the tune and plugs. On a 170 shot I'd probably have been running 30 base timing and an NGK 9 plug. I think the NGK 9 plug would be fine for the 225 hit with the tight .025-.026 gap. Pull 8* timing off your best motor tune, maybe 10* to be extra safe.
I'm about to go to a 300 shot with my 434ci setup and plan to back the motor down from 36 to 32, then pull another 6-8* out with the digital 6 box. I was running a 73 jet with the motor at 32 and pulling 4 more degrees out with NGK 9s at .026. Never burned a plug, but it may not have seen the full 175 hit that the jet was supposed to be either.
1 - 6 of 6 Posts
