I have a mandrel running a belt fuel pump off of the water pump pulley.
I have a 185mm crank pulley turning a 147mm water pump pulley. Then I run a mandrel off the water pump to my belt drive. The small pulley is on the water pump mandrel and has 25 teeth. The pulley on the pump has 68 teeth.
What percent of crankshaft speed is my pump turning???
Aeromotive recommends the pump to run at 50% crankshaft speed. Which is where I think I am???
Thanks, Matt.
Thanks, Matt.
