Hey guys this is my first big block build. its going in a 67 camaro with a 6 speed . It will be a 468 with a set of pro comp heads will be a street car that might see the track once a month at the MOST. I will be using a 150 shot when it does. stock rods stock crank. rod have been shot peened.(sp?) what im asking is what cam you guys would run. oh yeah it will be a hyd roller set up. and i want to keep the stock big block hood on it. so no room for a big tall intake. will prob run and RPM air gap. thanks for any and all help
