1 - 1 of 1 Posts
First here is my combo, 331 R block, sonny bryant billet crank, ross turbo pistons, grp alum rods, BES custom roller cam specs duration @.050 249int 249 exh , 114 lobe sep, .731 gross lift intake and exh. . Victor jr heads ported by BES, super victor efi intake , 120lb injec, fast xfi. Turbo kit is 1 3/4 headers ,2.5 crossover,3.5in down pipe, Pt8847, cold side is 3.5in piping ran through a garret intercooler has 6in core and is rated for 1300whp. My question is do you guys think the dp size is gonna be large enough to support 22psi and 1000rwhp, or will it create to much backpressure ?Forgot to mention the dp runs between the bell and firewall then heads straight back to a borla bullet muffler and a turn down before the axle. Also what do you guys think this combo should make for power , hoping to run 18-22psi. Is it possible to run this high of boost on pump gas with meth inj. ? Any advice would be greatly appreciatied , i am new to turbos , last setup was a novi2k. Thanks
1 - 1 of 1 Posts
