1 - 20 of 27 Posts
I have heard different opinions on my new combination and would like to get some feedback from the experts on what to expect HP wise. It is a 372c.i SBC. 4.125x3.48, 6.0 steel rod, JE 13cc dome piston .010 deck height 13.7: CR , Hellfire rings gapped at .025, .017 and .014 oil. Dart Little M block, Canfield 220cc 2.10x1.625., 62cc chambers, Shaft rocker system. Erson solid roller with 1.6 ratio .688-.656 net lift, [email protected] 108lsa, 104IC. Bowtie intake fully ported with a 1" spacer attached and ported to plenum opening, Pro Systems 950HP carb with additional 1" spacer. NOS pro race fogger with .028 jets. Here are the flow numbers for the heads w/o exh pipe:
I E
0.200 152.5 99.5 65.2%
0.300 215.7 166.3 77.1%
0.400 262.2 195.9 74.7%
0.500 290.2 210.2 72.4%
0.600 302.1 216.1 71.5%
0.700 309.6 218.9 70.7%
0.750 309.6 219.5 70.9%
625 / 640hp
Keith
N/A
keith
On a 4.125 bore you are only giving up 2.1cc's at .010" down. I am not sure you could even measure that hp wise. But it might give up some in the detonation resistance dept... Again not sure if i would even give it a second thought....
Wait and see what Chris has to say about it... I am not a big nitrous guy....
Keith
Discussion Starter · #7 ·
thanks Keith....appreciate the info...some of my friends have been kind of down on the combo. They like the 383 combo better than the short stoke big bore ones. But the car shouldnt be more than 3100-3200 with me in it so I think it will work
Who did the head work? This is a low port head? That's a pretty fat intake curve. Not saying it's not something that can be done, but a low port 23 degree head that averages 295 from .400 up is a pretty good piece.
Chris: The Canfield 220 head is basically a carbon copy of the last 23* head used in NASCAR. They work awesome. In the right hands, airflow is plentiful. Only downside, they REQUIRE shaft rockers. The off-set stud deal is a real dud.
Actually the intake side looks a tad low CFM wise. The exhaust w/a pipe would go 235'ish and that is where it needs to be.
When I do camshafts for those heads, typically they do not like tight LSA's AT ALL. Ecspecially is NOS is in your future. That is 2 steps not in the right direction.
HP.......Hmmm.......As Chris knows I hate those questions. At 3200lbs, with the ENTIRE COMBINATION set up for N/A, you have enough stuff to run 10.10's at about 132. However much power that is. In NOS trim, if you run it N/A, it'll make you not very happy. Mid to low 11's I'd guess.
Good Luck.
jsj372 said:
Jay,
Can I give you a call about possibly getting the correct camshaft for this combination. I would like to make the most of it before I put it together. I have a lot of time and $$$ in it so I want to do it right. Thanks.
Absolutely.
Today is Sunday and I am just answering E-Mails and PM's until the family gets up. I try very hard not to work on Sundays. Tomorrow, Monday, feel free to call me at 1.734.730.2574. If you get V/M, just leave a message. Lord only knows what I'll be getting into!
Thanks.
Discussion Starter · #17 ·
Chris,
Is it still common practice to paint the lifter valley of the engine? Have been out of the loop for a few years and am just getting back into this. If so, is there a special paint to use? What type of sealer is recommended for the freeze plugs? Using brass. Thanks.
It doesn't hurt to use Glyptol paint in the valley. I like to polish the valley with a grinder and a tootsie roll. It's never a bad thing to aid in oil return especially if the engine is not oil restricted up top.
1 - 20 of 27 Posts
