1 - 20 of 23 Posts
I have a 350 crate engine rated 300 hp. Wanting to make more hp. Working with about 3000 budget. Any ideas?
750 dp, rv cam, Eldabrock performer intake, flat top 4v pistons, and Headman swap headers. Building to make passes and not street.
If you’ve got $3,000, get some 2 valve relief forged, 0.043, 0.043, 3mm rings, and either get a better set of heads, such as 200 cc Darts, 2.05, and 1.60 valves, (unless current heads are comparable) change the cam, roller rockers, and girdles for 7/16 studs. Get a good valve job, have someone degree your cam in, and you’ve got it. Depending on what the vehicle weighs.
Discussion Starter #15
It's in a 97 s10 2door Blazer.
If it doesn't already have a better than stock rearend in it, you might be wasting time. That little 10 bolt is a extremely weak link in a dedicated drag car, especially a heavy one.
1 - 20 of 23 Posts
