1 - 6 of 6 Posts
This was a popular swap in the 70s. A couple companies made an adapter or spacer plate that went between the 833 mopar trans and the chevy bellhousing and came with the correct pilolt bushing/ bearing.. Also the clutch companies made a special disc, with mopar splines for this combo...I have not seen this stuff in years. All the crossover stuff is oriented toward the 5 & 6 speeds nowadays.... Try ebay or google it to find a source, Good Luck!
I have a centerforce clutch (little use), PP, and trans adapter plate for this setup. You will just need to shorten the input shaft on the trans.
1 - 6 of 6 Posts
