I have a 302 roller motor in a 67 mustang, I just got it
running but engine wasn't smooth. I put the temp gun
on each exhaust port and #5 is 40-60 degrees cooler
than the other 7 cylinders.
I checked compression first it is good so pulled the plug
and compared to other plugs the spark is weak. I figured
the cap may be bad so swapped new cap and its still weak.
I also swapped plugs and wires and still weak. The ignition
is a stock duraspark dist/MSD 6al and Blaster 2 coil.
any clue what I am running into??????????
