1 - 11 of 11 Posts
Brewmaster
Just had the porch light go out, how do I take the old bulb out and put a new one in? Already have the top off the light fixture to get to the bulb. :rolleyes:
Figures your from California!:-gay
Unoffical YB Fundraiser
first you need a bucket of water to stand in........
second the power needs to be on so you can see if the new bulb works when replaced.......
Stand in the bucket and untwist the bad bulb, please turn the bulb counter clockwise.....
Next dip your hand in the water and then place your thumb inside the area the bulb was removed from......
Do you feel anything ?
No, make sure the power is on and the breaker switch is also in the on position and repeat the step above.
Brewmaster
Discussion Starter #11
Toast made, bucket full, Mexicans mulling around confused... One just started doing yard work, wtf.
1 - 11 of 11 Posts
