1 - 10 of 10 Posts
a new combo or a redo of my combo,
81 luv 3200 w/driver
489 10to1 4340 rods,crank 4bolt studded
325 afr box stock, roller springs .750
edelbrock super victor, 1150
th400,super tight converter(big problem)
31x16.5x15 QTP, 4.30 35spline
the best it could do was [email protected] on a .73n/.62f
60ft 1.42, 660 [email protected] ...
i want to go 13 to 1, larger roller cam, and maybe port the heads and ???? what do i need to do, i want to go 8's @150+
If your 489 has a 4.25" crank buy a new block and pistons and make it a 565. I think that would be your best bet and then when you get the money get a new set of heads and a new intake(the super vic isn't so bad though). A 565 with those heads should make 825+ and it will help with your converter issue. That's what I would do.
That or spray it harder! I went 7.60s/4.90s with a iron headed 496 at 2650 pounds.:drinkers:
really !! did not know i could go that big with this crank ...
A 4.25" crank with a 4.60 bore is a 565. However your combo should be faster then it is. It takes about 700 horse to go 138 at 3200# so something is off. Your combo on motor should make at least 650. But before you dump a bunch of money into the heads I would start on a new shortblock. Plus if you want to get new pistons to change the combo just take your rods and crank and put it into a new block.
Raise the compression,get some port work on the heads,and get the converter and rest of the drivetrain right and you can run the numbers with a 489.
Filp's Elcamino runs 5.60's with a 496.
ya i seen it at dyno day, i know its 13to1 and big heads,cam .. so i really need a 13to1 496 combo on the sauce 200/250 !!
There's no doubt the stock block 496 combo works. I make 1150-1200 with mine on spray with some old iron heads. But if your going to raise the compression chances are your going to need new pistons. And its going to cost you at least $1000 to port the heads and intake and I think the heads and intake are a little on the large side now. Insteads of spending that money on that I would put it towards a aftermarket block. When its time to upgrade try selling a stock block 496 combo. You can't give them away.
Discussion Starter #8
porting the heads was just an idea, with the stuff i have but with 13 comp what cam size would you run, solid roller ??
If its a race car a solid roller is the only way to go. If your gonna go to a bigger bore I would put a set of 2.30 intake valves in it if your heads don't allready have them. Then again by time you spend 3k+ on a new block, pistons, and rings maybe you should sell your short block or keep it as a spare and buy this.
http://www.shafiroff.com/shortblocks/582_shortblock.asp
Discussion Starter #10
thats an idea !! how much should i sell the short block for 4bolt,studded,eagle 4340 crank rods(6.385),10to1 srp's(.030) o-ringed block..
1 - 10 of 10 Posts
