i posted this on the supercharger site also, could use the help
starting up my 522 BBC F2 reverse mount Chevy II
having issues with the EFI settings, i am new to this but have been getting valuble help from Ryan at steve morris and a buddy of mine.
finally got it running but plugs dripping wet and floods out fast, have to hold throttle 1/4 open to keep running
i did not want to contiue untill i had someone look over my file and see where i messed up
here is the major info
1967 chevy II
522 cid 4.560 bore 4.0 stroke
dart 320 heads, ported, 410 cfm @ 0.700" @ 28" great exh #s also
11.0 to 1 aries hard anodized pistons
roller cam i bought from steve morris, cam motion
3 bar holley map sensor
no idle air control motor
90 mm throttle body
holley TPS
T400 trans, no trans brake
4.56 rear gear
10" pro tourque nitrous/blower convertor
220 precision/seimans injectors
new edelbrock/curtis boggs super victor intake
T&D 1.7 rockers
i am starting the motor up on 93 octane pump gas and purple cam cam mixed 1/2 and 1/2, timing on a light is about 24-25 BTDC
here is my email address , i can send someone the holley file and look it over
[email protected]
i really could use some help, i am lost here
thanks in advance
1967 chevy II
90 mm throttle body
holley TPS
4.56 rear gear
T&D 1.7 rockers
[email protected]
thanks in advance
