1 - 15 of 15 Posts
· Registered
I cut a skylight in my bathroom and cut three of the copper water pipes in the plaster ceiling. After making bypasses around the hole cut I filled the system by opening valve to the feed. The manifold is a large cast pipe with smaller cooper pipe 3/8 ID coiming off to the rooms 10 total. Each copper pipe has a bleeder to let the air out. I did remove air from two zones. I turned the thermostat on and the furnace and pump kicked on but after a half hour of bleeding only on zone is getting hot water. This pipe is the closest to the pump. Thinking the zone was getting the most flow I closed the valve for that one zone thinking the pressure would push to the other that were still cold. Pressure on the system is around 11lbs. I made a appointment for a heating guy to come out but cant come till next monday at $115 an hour unless I want to pay for OT then 155 an hour. Any thoughts or procedures that I might of missed.
· Banned
Go to the furthest zone in the house from the boiler and bleed there.
· Registered
Discussion Starter · #8 ·
There is a large handle type valve on the return. I shut this valve and opened the drain and did get just a tad of air. The trouble I think is the incoming water from main has a direct path to the drain as the retun valve is above the water feed. Or with the main valve shut the water can bypass to the drain without going to any of the zones. Stumped I dont see anyway of forcing water through the differnt zones to push the airlocks. Also tried shutting the individual valves on the two zones that are flowing to try and force the pump to push with no luck.
· Registered
Discussion Starter · #14 ·
Does have a circulation pump ,not sure on how to turn up the pressure. Got a second one to flow after letting it sit over night got more air out. I'm still trying really not wanting to pay for something I should be able to do.
1 - 15 of 15 Posts
