1 - 3 of 3 Posts
We put a set of 225lb billet atomizer injectors on the car. Running BS3, shut off fuel pump, ignition on car will not turn off (0psi fuel pressure) only changes were injectors and injector offset was changed to 1.2 in bs3. Car is extremely fat, did not have this issue with 160's. Any help is appreciated
Discussion Starter · #2 ·
well we tried to make a blast and the damn thing smokes like a bitch, but yet it is adding fuel??? Never had this problem on the previous injectors. This is on a sbf with 106mm turbo. we tried another BS3, both are pre-2008 units:confused: unfortunately the 160's stayed at the shop if not wouldve tried that too. any sugestions??
Did you try some of the things we talked about this morning? What about some of the other problems you mentioned?
1 - 3 of 3 Posts
