1 - 5 of 5 Posts
I have a 92 Camaro 305 TPI automatic that is all stock. I thought that I was having an issue with the lockup switch but messing with the car in the driveway I don't think so anymore. Most of the time the car will die when I put it into drive or reverse and take my foot off of the brake pedal but when it will keep running and I drive it down the road it will buck and about die and come back up over and over. Well the other day I was in the driveway with it and was not using the brake pedal at all. I could leave the car in neutral and let the car roll down the driveway not using the brake pedal at all just using the e brake handle. It runs fine in neutral but once i let the car move at all even in neutral it dies ( again no pedal just e brake). I am thinking something with the vehicle speed sensor or speedo sensor. Leaning towards the VSS. If anybody knows about this please help me out. Thanks.
just letting it roll, no throttle? the vats system can shute the car off if its faulty, but you have to give it more than 1/8 throttle i believe before it kills the fuel pump.
sounds like a dirty TB, or a bad idle air control motor (IAC) could be the fuel pump dying. the TPI needs a decent amount of pressure to run. rent or buy the proper gauge and check pressure at the rail. there is a fitting on the passenger side. there should be a black cap on top of it, but chances are its gone.
No throtte applied. I have not checked fuel pressure yet because I have ruled that out in my mind from reading posts on Thirdgen.org and everyone with problems replaces their fuel pump and it does not fix their problem. I did also think about the VATS. How do you test that system. Sorry for all of the questions. I don't want to put alot of money into tis car because I bought it to resell it. I drove it home from about 25 miles away then drove it a coupl of times a short distance then it started to screw up and I just want to fix and sell. It is a 92 25th anniversary Z28 Which out of 70,xxx Camaros that year only 5,xxx were Z28's. Thanks for the help.
well, you can check it the old hillbilly way. get a friend you dont like much and have him stand in front of the car and spray carb cleaner or gas in a spray bottle into the TB before she dies and see if it stays running. that will tell you if you have a fuel related issue. if you run him over, no big deal.
seriously, though. have him stand to the side of the car and just run over his foot if you dont like him.
I figured the problem out. It seems to be the vehicle speed sensor (vss). I had previously looked at this plug about a half a dozen times and never unplugged it because I was so heart set on it being the lockup switch. Then when I noticed that it died in neutral like it did I knew it had to be something else. So today I slid under the car and unplugged the sensor and then drove the car and it ran great, so I will replace the sensor and it should take care of the problem. Thanks again.
1 - 5 of 5 Posts
