1 - 7 of 7 Posts
Need advice, I have a 383, powerglide 1.76 gear and the car needs more gear in it. On motor I have trapped at 118 at 11.3, i changed the converter to a ptc nitrous converter. Best on motor now is 11.5 at 118. on nitrous I am expecting to be going high nines/ low tens I have only made a 1/8th pass on a 100 hit and have been 6.80 @ 102 in the eighth with no timing in it. Im going to be upping the pills and would like to put a gear in it to help out. The car starts to die off at 5,800 and up. already checked/changed everything. I used the calc and it says im imbetween a 3.73 and a 4.10. Just need some advice, thanks guys.(rear is a ford 8.8, yes I have a chevy setup in a mustang, and yes it was the best damn thing I have done!)
i'm expecting to shift at 6200 and trap about 6200 or less w 28"tire,456s was still under 7000
Chevy setup? Are you in a class where you needed to slow it down? JK Im fighting the same thing right now. At 1000 ft im on the rev limiter 6000 @ 140.2 im switching to 3.55 want to hit 150 @ 6k
i may have to rethink after a few passes its a new car with new pg i got it w 430s and fig itd be perfect!we'll see btw this is an extra car that gets all the leftovers from the other projects if it runs 11s at 120 or so im happy
1 - 7 of 7 Posts
