1 - 2 of 2 Posts
it is a bbc cast iron head 498 13.5.1 motor was thinking of putting it 36n 32f with 19 total timing from 36 with 5.75 fuel pressure cam is 748 748 on a 112dur is 276 286 i think any help would be app.
I wouldn't use a 36 pill as a starting point. Personally, I'd start with a 28N/20F @ 20* and slowly work up to a 36 pill, reading plugs/timeslips along the way. If the carb is correct, I would expect you to end up with 36N/26F. JMO.
1 - 2 of 2 Posts
