#06-01-39-002C: Blower Motor Inoperative or May Not Shut Off in Extremely Low Ambient Temperature Conditions (Replace Blower Motor Control Module) - (Jan 18, 2008)
Subject:Blower Motor Inoperative or May Not Shut Off in Extremely Low Ambient Temperature Conditions (Replace Blower Motor Control Module)
Models:2004-2007 Buick Rainier
2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2007 Chevrolet TrailBlazer Models
2007 Chevrolet Silverado (Classic)
2003-2006 GMC Sierra Models, Yukon Models
2003-2007 GMC Envoy Models
2007 GMC Sierra (Classic)
2003-2004 Oldsmobile Bravada
2003-2006 HUMMER H2 Models
with Automatic Temperature Control HVAC System (RPO CJ2)
This bulletin is being revised to update the model years that are affected and add the Oldsmobile Bravada. Please discard Corporate Bulletin Number 06-01-39-002B (Section 01 -- HVAC).
<A href="#ss1-2049899">
Condition
Some customers may comment that the blower motor is inoperative or continues to run after the vehicle has been shut off.
<A href="#ss2-2049899">
Cause
These conditions may be caused by a blower motor control module failure. This failure may occur when the vehicle is operated in ambient temperature conditions of -23°C (-10°F) or below.
<A href="#ss3-2049899">
Correction
Important: Replace the blower motor control module if the vehicle experienced a blower motor control module failure in extremely cold ambient temperature conditions.
Technicians are to replace the blower motor control module, also called the Linear Power Module (LPM), with the P/N listed below. Refer to either the Blower Motor Control Processor Replacement or Blower Motor Processor Replacement-Auxiliary procedures in SI. After replacement of the blower motor control module, the customer may notice a slightly higher than expected blower motor speed at any of the blower speed settings.
<A href="#ss4-2049899">
Parts Information
Part Number
Description
Qty
89018849
Module Assembly, Auxiliary Blower Motor Control (Rear System on Escalade ESV, Suburban, Yukon XL)
1
89018964
Module, HTR & BLO & A/C CONT (Front system only vehicles - Except H2)
1
89023355
Module Assembly, Blower Motor Control (H2 Models)
1
89024926
Module Assembly, Auxiliary Heater & A/C Control (Rear System on Escalade, Yukon, Tahoe)
1
<A href="#ss5-2049899">
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D0890
Module, Blower Motor Control - Replace
Use Published Labor Operation Time
Add
Diagnostic Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
