1600 hp might be tough with turbos that small. I had turbonetics 66's on a 346 cube LS1 and went as fast as 161 at 3450 lbs on 22 lbs of boost. I guess that's in the 1100 hp range but I just don't see it picking up another 500 hp because you're really getting out of the turbos efficiency range if you start going up too high in the boost.its a 331 sbf with 2 66mm turbos and it weighs 3300 with me in it...i live in western nc....
Mike (Mr. Ridings Automatics above) is a modest guy but he really knows his stuff when it comes to th400s (and countless other trans as well). Hutch is another stellar choice as well.I just wanted to make sure you you wasn't in Glide range. Street driver or pure weekend only race car?
Ton of good 400 builders, you couldn't go wrong: hutch,kilgore,CK perf, myself, frizzo, mikes transmision, ATF, rossler,coan. i could go on forever. With this list, i'm glad I build converters too.
I have one of their spragless TH400's with griner VB and 2.10 gearset. Couldn't be happier. We are throwing 1400hp at it now and I am told it will take whatever we can come up with so 1600hp is not far off. The spragless direct drum is bullet proof from what I am told.check these guys out www.extremeautomatics.com They build 400s for fast cars
All of Lonnies spragless stuff is the shit...I have one of their spragless TH400's with griner VB and 2.10 gearset. Couldn't be happier. We are throwing 1400hp at it now and I am told it will take whatever we can come up with so 1600hp is not far off. The spragless direct drum is bullet proof from what I am told.
lol the turbo doesn't know that its label says 800 hp though. It only knows pressures, speeds, flows, and efficiencies.they flow 80 lbs. of air not 800 sorry....if the compressor map says 800 hp each then why not.....
I am confused about this statement? When determining how much horsepower an engine will make you have to calculate the air flow requirement for that engine based off of engine displacement, VE RPM, AFR, BSFC and other parameters. Knowing the variables you can caculate (spreadsheet) engine airflow requirement for each engine operating point, know as an engine lug line. Then you can plot these points on the compressor map to see if it will supply enough air for that operating condition. If your points do not go into choke the turbo will support that power. If the points go into surge that means the engine can not handle the air flow the turbo is flowing and causes the compressor wheel to surge.lol the turbo doesn't know that its label says 800 hp though. It only knows pressures, speeds, flows, and efficiencies.
