I'm running 60lb. injectors with a 1.1ms opening time, around 500hp to 6500rpm or so, on E-85; idle PW is around 4-4.5ms on my 362cid mill.
All I did was set fuel pressure to 45psi referenced to atmospheric, but I'm thinking I can get more tuneability in the lower RPM range if I reference to vacuum and lengthen those PWs down low.
Thoughts?
Thoughts?
