1 - 20 of 67 Posts
As you all know we've been working on getting my car running again. We have it up and running. My original 8inch rear-end blew up at the track. So we built a stout D60 for the car. Brand new everything in the rear-end. The richmond gears are brand new backlash set at 9 thou. It also has a detroit locker in it.
My trans is a t350 it was not pulled out and looked thru. Only thing we did to it was replace the trans seal as it was destroyed when the driveshaft bent in half.
I have been driving the car alot over these past few days. The trans shifts fine just as it did before. Just firm shifts not lazy on the shift either. Feels normal. I've ran it hard and it shifts fine.
The Car is making a wierd very high pitch whistle sound at certain RPM's. It doesn't do it all the time you have to gas it just right for it to make this noise. You can hear it pretty good too. I've tried to shut the motor down and coast it in N and their is no noise. Fire it back up and proced and the whistle is back.
It does have a alum DS. could the DS be making this noise? Like a aluminum hummmm.
Any idea's what this mysterious nise is?
Also found out my slip yoke is leaking at the back where the freeze plug is. We are sure its the slip yoke leaking and not the rear seal. We do not see any oil anywhere near the tail shaft. It looks to have sprayed it all over the floorboard like it was flung up. It's a brand new slip yoke.
this is what happend back in april 2008
Well, it's either 1 of 2 issues...
1. You have this: http://videos.topredline.com/recentvideos/0/b20096ec-0f2c-4f99-9227-80934fb999c2.htm
or
2. The drivshaft was not dynamically balanced for the tire diameter and RPM range you drive in. If it wasn't, then yes, you'll hear harmonic distortions as the driveshaft tries to tear itself out of the car. A good driveshaft company asks you your tire diameter, rear gearing, and engine RPM you go through the traps at. They then balance the driveshaft so that you either never get into the distortion, or that you blast through it so fast it barely occurs.
Let me guess, you did nothing more than tell them the length and they sent it to you?
It's not number 1. But that was funny. The whistle doesn't sound like that either.
Hmmm I didn't order the driveshaft. The guy doing the work ordered it. I don't know if they asked him all those questions.
It is a inland empire driveshaft. The slip yoke is leaking. I paid over $500 for that DS and Slip yoke and the slip yoke is leaking at that plug
We were thinking of wraping a piece of rubber around it somehow and seeing if it would absorb the noise.
You think that would work?
I think I posted this before but no one responded..............that transmission looks to be on quite a downward angle............is the pinion angle set to match? I always thought 4* was about right and that appears (maybe its just the pics) to be way more that 4*.
Discussion Starter · #10 ·
i can try and get a better pic of that angle if you'd like. But it will have to wait till tomorrow. That trans have been like that for over 6 years. Hasn't been touched.
So your pinion is pointing up? (in relation to the trans angle) The pinion angle should match the output shaft angle of the trans. 4* down is about optimal on the pinion.
i think it is pointing down a bit. That way when you accelerate it goes up to match.
That would be correct (and in theory it is) but in would appear that your trans is pointed downwards pretty severely when it should be approx. level. Personally I would put an angle finder on it (the output shaft of the trans) to make sure. I'd hate to see you take out another shaft and rearend. The origional may have lasted 6 years but it doesn't mean it was right. Just my $0.02.
The pinion angle (from your pics) looks not to bad but the views can be deceiving. Just as the trans may not be an issue but from the pics, it looks out.
1 - 20 of 67 Posts
