1 - 18 of 18 Posts
Discussion Starter #12
Just starting to make a lot of progress, suspension front and rear sorted.Body almost done.
Just a few small bits to do now, these are the bits that take time.
Still to do;
Shorten and mount steering column.
Rerurb front calipers.
Run all the brake lines
check out rear brakes.
Connect hand brake
Machine reducer etc for the two half of the prop shaft.
Fabricate a fuel tank.
And last but not least........wiring.
Seems a lot when you write it down.
As normal you can see my progress at www.ratroduk.com
Lazy
Discussion Starter #15
Almost complete now, had to leave building the rat as I have been racing my Capri at santapod. Race car has been put away and the building of the Rat continues. Progress can be found at www.ratroduk.com.
Thanks to all that have visited my site....Lazy
Discussion Starter #16
Allmost there, taken a bit longer to complete than I planned for. Just need to wire the Rat and check over a few things and we are ready to go.
See up dates at www.ratroduk.com
1 - 18 of 18 Posts
