1 - 6 of 6 Posts
mustang 2800lb car
glide 1.80 gear t brake
315 drag radials
bbf with n20 plate
wanna be roughly 6500-6700 thru traps
and radial prob plays a factor gonna spray 200-250
The radial is not going to grow much but you will have to nail the converter perfect. I agree with the actual tire size making a big difference.
Should have asked this also, how much power do you think its going to make approx. That will effect the gear selection as well, less power may need a lower gear to get the car moving, where a higher HP deal can get away with a little higher gear to get wheel speed up and it will MPH better. The proper torque converter will help this but I'm a clutch person so I have no idea about that.
1 - 6 of 6 Posts
