1 - 20 of 24 Posts
I am frying some electronic items on my car since i switched to a 16 volt battery setup. running 2 turbo start 16 volt batteries and 1st my moroso accumulator solenoid fried, then interior light bulbs and 2 gauge lights and now my moroso electric water pump.
what else is going to fry and do i need to put a step down on everything but the starter?:confused:
I ran a single 16 volt battery for years without any problems. Last year I needed some ballast so I added a second 16 volt battery. I couldn't keep headlights in my car once I added the second battery. I never did understand why (2) 16 volt batteries started cooking things and (1) battery everything was fine.
Tellin' it like it is
For the bulbs, you could probably go to LED bulbs to get them to live. As for the pump, switch to a top shelf deal like a CSR and you'll be fine there.
What kind of voltage is the alternator putting out?
50Sick
Something isn't right . I run two 16 volts with an alternator putting out 18-18.3 and have had zero problem. We do step down the voltage on the electric shocks however everything else works well. I know everyone complains of the brightness on the headlights but everything else has been good.
do not know the answer to your question, but i was wondering if depending on how they are wired could the voltage double if they are in series like a golfcart does? kicking them up to 32?
Yes, if you wired them in series the output would be 32V. They should be wired in parallel.
coffee extraordinaire
yup. That is the 1st thing I thought of. But I am assuming he at least he had a voltmeter to check the voltage.
This is what we need to know....what is the voltage reading. The 1st & most simple step.
A 12 volt system charging system in most cars will generally produce a voltage between 13.5 and 14.4 volts while the engine is running. It has to generate more voltage than the battery's rated voltage to overcome the internal resistance of the battery.Putting a alternator on a 16 volt system should produce close to 19 volts.I find that using a 12 volt system with an alternator in race cars works excellent while avoiding without the problems created by a 16 volt system.
I run duel 16volt batteries and alternator. I have had zero issues . I use the spaghetti menders system in my car.
Discussion Starter · #16 ·
Yes i got the batteries parallel. positive to positive, negative to negative.
i use 2 tubo start LIGHT WEIGHT BATTERIES because 1 liteweight 16 volt cant hold a charge going rounds so i added another battery. The electric water pump was a moroso that bolts to the stock water pump housing.
just went with a meziere same style. hope this one lasts.
Unless your needing extra Voltage to maximize a fuel pump i would use 12v battery with an alternator. Not sure why you would need two 16s with an alternator:confused: The newer alternators like fords 3G etc are rated 14.4 volts. I use one 16V battery in my race car with an alternator set to 18 volts. My adjustable regulator should be set at 18.8 volts but i don't do it because of ECU. When i go to a belt drive fuel pump i will put 12 volt back in. You can buy a 12v step down to run your lights or that twin post 12v/16v battery.
1 - 20 of 24 Posts
