1 - 7 of 7 Posts
Has anyone ever ploted a stock suspension Mustang Fox body's instant center length and height?
Thats a pretty big difference, mine is behind the door and 9-10" off the ground.
what arms are you running? when i did the 95 it was around 75" out and 9 up but the older foxes were a little shorter if i recall. that would put you around 20" out and 9 up.
Wolfe uppers and lowers, 17" infront of the rear and 9" off the ground.
to the best of my knowlege it would be almost imposible to have an IC at that point. the lower arms are 17.5 long themselves and the uppers are around 9", that would put you uppers pointing almost straight down, are you sure youre measuring IC correctly?
1 - 7 of 7 Posts
