1 - 5 of 5 Posts
Anybody ever save any weight tinning the floors in their stock suspension mustang with aluminum? Basically building a 25.5 cage, but removing the factory floors and replacing them with aluminum. Is there any weight savings or is it a wash?
my buddy has the floor cut out of a car , i'll try to get a weight from it if no one responds
doesn't feel very heavy though , just like most of the sheet metal parts on a stang
this doesnt quite answer your question, but..... i cut out the floor and frame rails from start of the rear floor to the back, and weighed it , it amounted to a little over a # 100
you also cant have alum, on drivers side under driver so you wouldnt be taking out that much
Dont forget, when you cut the factory floor out, you will need the x-bracing in the floor.....Im sure this is the heavier route...
1 - 5 of 5 Posts
