we have a 03 GT automatic, approx 80k miles. the car has a metallic clunk/snap that is very evident when going from coast to drive at 40-60 mph. i know there is a tsb stating a tip in driveline clunk is normal but this is loud and very metallic
car has new (less that 3k miles) upper and lower control arms, freshly rebuilt trac loc, new ujoints. makes the noise with and without the quad shocks on, same with rear sway bar, and same with rear shocks. we have check control arm mounting locations, shock mounts, trans mount, ujoints, diff backlash, no play in axle bearings, etc
listening with a stethoscope, it is most evident on the diff cover both before and after the trac loc rebuild. but im having a hell of a time pin pointing it and fixing it
any suggestions?
thanks
any suggestions?
thanks
