1 - 4 of 4 Posts
Is it difficult to change the 3rd gear ratio to make it closer to 4th gear ratio ?
Confused Racer
Not worth it in a muncie. actually you can only get standard gear sets for that trans nd they are getting hard to find
Get a hold of Nathan over at Autogear he can help you with any gear ratio you might need for a Muncie they manufacture parts and import Italian gear sets. I built a Autogear M22Z trans for my 57 -drilled main shaft custom gear set , works flawlessly will handle up to 800 hp.
Steve
1 - 4 of 4 Posts
