So
I got some more funds together and its time to take the car back out.
Get the motor running as close to perfect (timing and plug reading) then retard the timing to the setting we have for our tune up on 1 kit. Burn out, stage , purge then hit it and afterwards read the plug and it should be clean. Adjust fuel pressure and timing accordingly.
Then try the second system by itself and do the same as above. Then try both the first then ramp the second
OR
Run the first system and add the second .run to the 1/8th mile then recheck it before making a full pass. Kinda forgetful trying to remember
OR
